Community Member
Cisco7600 PBR
Is "policy based routing" on Cisco 7600 (i.e. with sup 720 B) done in hardware or software?
regards,
A.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco7600 PBR
Hello Antonio,
it is done in hardware by programming TCAM tables but not all possible set actions can be available.
see
The Policy Feature Card (PFC) and any Distributed Feature Cards (DFCs) provide hardware support for policy-based routing (PBR) for route-map sequences that use the match ip address, set ip next-hop, and ip default next-hop PBR keywords.
When configuring PBR, follow these guidelines and restrictions:
The PFC provides hardware support for PBR configured on a tunnel interface.
The PFC does not provide hardware support for PBR configured with the set ip next-hop keywords if the next hop is a tunnel interface.
If the MSFC address falls within the range of a PBR ACL, traffic addressed to the MSFC is policy routed in hardware instead of being forwarded to the MSFC. To prevent policy routing of traffic addressed to the MSFC, configure PBR ACLs to deny traffic addressed to the MSFC.
Any options in Cisco IOS ACLs that provide filtering in a PBR route-map that would cause flows to be sent to the MSFC to be switched in software are ignored. For example, logging is not supported in ACEs in Cisco IOS ACLs that provide filtering in PBR route-maps.
PBR traffic through switching module ports where PBR is configured is routed in software if the switching module resets. (CSCee92191)
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/layer3.html#wp1027016
Hope to help
Giuseppe
1 REPLY
Re: Cisco7600 PBR
Hello Antonio,
see
Hope to help
Giuseppe
1415
