Citrix Remote Access
We are using Citrix Presentaion Server 4.0. Our users connected to lan use ICA client or Internet Explorer to access apps. My remote users are telecommuters and a branch office. Both types of remote users were getting disconnected after 15 minutes. I modified Keepalive parameters in IIS for Citrix web access. This resolved issue for telecommuters getting disconnected. My lan subnet is 10.1.0.0/C and my branch office is 10.3.0.0/C. These users access Citrix server with Internet Explorer but I continue to get timed out. It seems my keepalive is not getting to my branch office subnet. I have 2 Cisco 1600 routers running IOS 12.0. Below is a config. Both routers are configured the same.
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service tcp keepalive in
service tcp keepalive out
service password-encryption
ip domain name test.com
ip subnet-zero
interface Ethernet0
ip address 10.1.0.253 255.255.255.0
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
no cdp enable
interface Serial0
ip address 192.168.4.2 255.255.255.0
router rip
network 10.0.0.0
network 192.168.4.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.0.51
ip route 10.3.0.0 255.255.255.0 192.168.4.1
no ip http server
Danny
Bronze
Re: Citrix Remote Access
i ve tested a cirix metafrane xp before for a remote location it worked just fine, but the keepalives you r talking about did you mean the keepalives of the line or of tcp ...
i think there s a ICA prameter to check that disconnects them out after a while of inactivity, what you can do isolate the problem just keep doing someting from the client till the timeout expires and see if you get disconnected ?
I have resolved issue for remote users via Internet using IE. This problem is isolated to users on subnet 10.3.0.0/C connecting to 10.1.0.0/C. It seems as if keepalives are not received by users at branch office.
392
