Clear config on Cisco 837?
whiteford
is there an easy way to completely remove the config on a Cisco 837 router and get the config back to when we bought the device?
graemeporter
Hi there,
If you mean to blank the config, so that the router is back to factory defaults, then the command to enter is "write erase", which you should enter in enabled mode (not in global config mode).
If that's not what you meant, then please elaborate!
Kind regards,
Graeme
