Webcast-Catalyst9k
clear ip nat translation
We use ip nat to let users connecting to the internet through a 2621XM.They can connect but each hour, we have to do a "clear ip nat translation" , otherwise, the router is too slow, it takes many seconds to write one command.
Is there anything we can do to avoid it or is there a way to launch "clear ip nat translation" automatically every 30 munites for example?
Re: clear ip nat translation
the default NAT timeout for dynamic entries is 24 hours. You can change this default value by issuing the 'ip nat translation timeout seconds' command from the global configuration mode.
Which IOS version are you running ? Can you post the output of 'show version' ?
Your problem sounds could be related to an IOS bug as well...
As for scheduling commands, check the link below for an explanation of the Cisco command scheduler:
Command Scheduler
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_feature_guide09186a00801b0695.html
HTH,
GNT
Silver
you can use 'kron'.
Please check my conf, and change as you wish:
kron occurrence clear in 1:0:0 recurring
policy-list CEF
policy-list NAT
policy-list ARP
kron policy-list NAT
cli clear ip nat translation *
kron policy-list CEF
cli clear ip cef * prefix-statistics
kron policy-list ARP
cli clear arp-cache
Hope this helps
Andrea
we've put
"ip nat translation timeout 60".
the router seems slow.
here's it's show ver
Silver
when an entry is first placed into the NAT table, a timer is started; the period of the timer is the translation timeout. Each time the entry is used to translate the source or destination address of a subsequent packet, the timer is reset. If the timer expires, the entry is removed from the NAT table and the dynamically assigned address is returned to the pool. Cisco's default translation timeout is 86,400 seconds (24 hours).
Defaults:
timeout 86,400 sec
dns-timeout 60 sec
finrst-timeout 60 sec
icmp-timeout 60 sec
port-timeout tcp 60 sec
port-timeout udp 60 sec
syn-timeout 60 sec
tcp-timeout 86,400 sec
udp-port 300 sec
'timeout', 'tcp-timeout' and 'udp-port' are non port specific ... that is, maybe you have a lot of "non port specific" translations, and now your router works too much.
Check 'sh proc cpu', 'sh proc mem' and 'sh ip nat statistics'
Hope this helps
Andrea
yes, it seems the router works too much.In "show proc cpu hist", we've got about 90.We've tried different value of "ip nat translation timeout", still the same.
We haven't specified any tcp-timeout nor udp-port.
Silver
without 'ip nat translation timeout' command, the cpu works fine?
please check this:
no ip nat translation timeout x
Andrea
no, we've had to launch the command each 30 mn
Silver
mmm ...
router is a 2621XM, is it? IOS?
try to enable CEF, and last resort:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d09f0.html
maybe it does the trick
Please let me know
Andrea
Hi Andrea,
cef 's already enable.
Thanks for all, for your help and documents
5161
