Webcast-Catalyst9k
clear ip ospf redistribution
We have encountered routing problem on one of the IP block from our distribution router where the IP from that block is unreacheable to other networks. Some router shown that the routing entry known from the router it was connected while other router is not. With this, we've tried to command the "clear ip ospf redistribution" where as the connection went back to normal and the routing table have seen the proper routing.
Could anyone help us to avoid the repeat of this problem?
1 REPLY
Silver
Re: clear ip ospf redistribution
How often are you facing the problem? If it not on a regular basis, you can use the same command "clear ip ospf redistribution"
224
