02-11-2008 11:20 AM - edited 03-03-2019 08:39 PM
What command would i use to clear all of the data in a 505 PIX? I want to keep the current IOS, but get rid of the routes and start fresh?
-J
Solved! Go to Solution.
02-11-2008 11:47 AM
To set it to factory defaults and keep PIX code issue.
PIX(config)#configure factory-default
or you can define an IP address of your choice for inside interface and all other configuration will be set to factory defaults.
e.g
PIX(config)#configure factory-default 10.10.10.1 255.255.255.0
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/c.html#wp1055799
rgds
Jorge
02-11-2008 11:47 AM
e.g
rgds
Jorge
