07-28-2009 10:21 AM - edited 03-04-2019 05:34 AM
Can anyone help me to know how the clear the REFLEXIVE ACLs created during traffic passed thru the Router.
Reflexive IP access list SAIRAM
permit tcp host 218.248.17.113 eq telnet host 192.168.1.1 eq 21474 (26 matches) (time left 294)
I know to use the "ip reflexive timeout x" command to change the default timeout of 300 sec to some assignable time
But how to clear the dynamically created REFLEXIVE ACLs.
I tried with "clear ip access-template". But no use.
Thanks in advance
Sairam
Solved! Go to Solution.
07-28-2009 11:13 AM
There isn't any method for clearing a reflexive ACL entry. As you indicated, you can manipulate the timeout value to make this feature somewhat more secured.
HTH,
__
Edison.
07-28-2009 11:13 AM
HTH,
__
Edison.
