Webcast-Catalyst9k
Clock rate on 3640
Hi all,
I have a 3640 cisco router with IOS Enterprise w/ SNASW.
The serial 0/0 interface has the clock rate command by default. When i 'm trying to remove this command by:
#no clock rate
i got the following error:
FECPM PM doesn't support clock rate 0
When i connect a DTE cable, it is the same thing even if i entered encap x25 dte.
any ideas?
Rds,
silvere
1 REPLY
Bronze
Re: Clock rate on 3640
"FECPM PM doesn't support clock rate 0"
Please attach a DTE cable and do a shut/no shut on the interface and this will remove the clockrate.
Here's a basic summary of the possible cause:
Cisco DB-60 serial interfaces can be used for many different types of cables, so when one is
connected, the router goes through a routine to determine what kind of cable it is. DTE cables have
certain pins "jumpered" together, so the serial interface can detect that it is a DTE cable; DCE
cables do not have this. As a result, if you've never plugged a DTE cable into the interface (or any
cable for that matter), the router assumes that the interface is to be used as a DCE device, for
which the clockrate command is mandatory and cannot be removed. A quick fix: plug a DTE cable into
the interface, do a "shut" then "no shut" on the interface, wait for few seconds for the serial
interface's controller to figure out that it's a DTE cable, and the clockrate command should
disappear from your configuration. To verify, type "show controller serial 0" to check what it
thinks the cable type is (V.35 DCE, RS-232 DTE, etc). Once this information has been updated in the
controller, you should be good to go!
Did you do a "shut/no shut" when you connected the DTE cable?
276
