Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
command for controller
I want to know if the command ? Channel-group 0 unframed? is available in the router 3640 with a 12.3 version.
if not what is the solution?
Bronze
Re: command for controller
i beliave it is available
# controller S 0/0 press enter, put ? , it will give you different combincation,
i hope this will solve your problem
-Minu
it not exist!!!
router(config-controller)#?
Controller configuration commands:
channel-group Specify the timeslots to channel-group mapping for an
interface
clock Specify the clock source for a DS1 link
default Set a command to its defaults
description Controller specific description
exit Exit from controller configuration mode
framing Specify the type of Framing on a E1 link
guard-timer Guard timer (0-20) for xcsp calls - timer duration and
accept/reject on expiry
help Description of the interactive help system
linecode Specify the line encoding method for a E1 link
loopback Put the entire E1 line into loopback
no Negate a command or set its defaults
pri-group Configure the specified timeslots for PRI
shutdown Shut down a E1 link (send Blue Alarm)
router(config-controller)#channel-group ?
<0-30> Channel number
router(config-controller)#channel-group 0 ?
timeslots List of timeslots in the channel group
what is effect of this command"Channel-group 0 unframed"
10xs
Are you trying this with E1 or T1 link ?
This option is supported only with E1 link.
regds
106
