Command to power down the router
tselvan
Hi All,
Is there any command to power off the router from the command line.(Or)the only possible way is to manually switch off the power??
Thanks in Advance,
2 Accepted Solutions
spremkumar
Level 9
Level 9
You dont have a cli to power off the router as you have in case of servers wherein u can make use of init command to do so..
regs
There are no commands to actually power off the routers.
Cisco is going to introduce in the new 6500 series switches which will have an option of reloading the device which will be seen as a power off and power on.
But again its a hard reload as against switching off.
regards
Narayan
spremkumar
Level 9
Level 9
regs
regards
Narayan
Thanks Narayan for your quick reply.
Thanks Prem for your prompt reply.
