Command used to verify Interface Speed
My ISP Provider say's that he is providing 2MB Speed how cvan i verify that he is providing.is ther any command which can be used in the ISP router
Re: Command used to verify Interface Speed
hi,
check the speed using PRTG or some other monitoring software.
hI,
You can check the incoming and outgoing traffic utilizaton using MRTG.
please rate if you find this usefull
regds
Adhi
91
