Community Member
Communication between VRF on same PE routers
A---------PE-1--------P----------PE-2
           B
Am connecting to different customers on same PE and they want to communicate with each other,after importing route-target the next-hop for customer-A routes from Customer-B, is the interface associated with customer-A VRF on the PE-1 router,Customer-B is not able to ping the interface of customer-A,Because here they are not receiving a MBGP update the next-hop is the connected interface of another VRF. To make them reacheable what i have do????
Solution:
Pointing static VRF routes to global routing table of PE-2  and in global routing table of PE-1 pointing global static route to networks of CUSt-A with  particular next-hop of associated VRF interface and redistribute the global static routes in dynamic routing protocol then only PE-2 will come to know where the routes are located for customer-A.By doiing this the traffic flow for connected customer is through PE-2.
Any alternate solution guys
1 REPLY
Hall of Fame Super Silver
Re: Communication between VRF on same PE routers
Hello Lambay2000,
you need to redistribute connected in address-family ipv4 vrf VRFA
router bgp xx
also you need on each VRF to import the route-target used for export in the other VRF
ip vrf VRFA
rd  100:101
route-target import 100:200
route-target import 100:100
route-target export 100:100
ip vrf VRFB
rd  100:102
route-target export 100:200
Hope to help
Giuseppe
543
