Communication btw different Vlan between 2 L2 Switches... Can anyone understand me how it works
Hi all,
I went through one interesting question which is asked by my colleague, but i given wrong info to him.. :) Same i have simulated in GNS3 and found to be working fine.
I have attached the diagram for reference: Communincation between 2 differnce Vlan between 2 L2 switches..
Interface connected between 2 L2 switches are part of dieeferencet Vlan (access-mode) and switches throwing %CDP-4-NATIVE_VLAN_MISMATCH error, which is expeted.
*Mar  1 00:08:15.635: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet1/1 (10), with R4-SW FastEthernet1/1 (20).
But tried to ping machine (Router with no ip routing) which of differnt Vlan 10, 20 (Vlan 10 --> 10.0.0.1, and Vlan 20 --> 20.0.0.1)..and it is successfull.
R1#ping 20.0.0.1 rep 100
Sending 100, 100-byte ICMP Echos to 20.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 12/30/52 ms
R3-SW#sh cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
R4-SW            Fas 1/1            131          S I      3725      Fas 1/1
R1               Fas 1/0            121          S I      3725      Fas 0/0
R5               Fas 1/2            176          S I      3725      Fas 0/0
R3-SW#sh run int fa1/0
Building configuration...
Current configuration : 84 bytes
interface FastEthernet1/0
 switchport access vlan 10
 duplex full
 speed 100
end
R3-SW#sh run int fa1/1
Current configuration : 94 bytes
interface FastEthernet1/1
 shutdown
 duplex full
 speed 100
R1#sh run int fa0/0
Current configuration : 111 bytes
interface FastEthernet0/0
 ip address 10.0.0.1 255.255.255.0
 no ip route-cache
 speed 100
 full-duplex
end
R4-SW#sh cdp neigh
R3-SW            Fas 1/1            179          S I      3725      Fas 1/1
R6-SW            Fas 1/2            145          S I      3725      Fas 1/1
R2               Fas 1/0            166          S I      3725      Fas 0/0
R4-SW#sh run int Fas 1/0
 switchport access vlan 20
 duplex full
 speed 100
end
R4-SW#sh run int fa1/1
 duplex full
 speed 100
R2#sh run int fa0/0
 ip address 20.0.0.1 255.255.255.0
 no ip route-cache
 speed 100
 full-duplex
end
If interface between 2 switches are Trunk, as expected it wil not allow communincation till the presence of L3 device.
Success rate is 0 percent (0/63)
I think, that access port
I think, that access port removes VLAN tag when traffic leaves it. So when traffic comes  from SW1 to SW2 or viceversa it is not tagged with any VLAN and succesfully reaches the destination.. In case trunk configured, we would receive marked frames and it would be dropped due to VLAN mismatch. That's my thoughts..
Hi D, Again if tag is removed
Hi D,
Again if tag is removed while frame coming out from egress interface (if we configured switch port mode access) then is it take default vlan and communincate each other ????If it so then in both switches i have configured to match the packet of Vlan10 and Vlan20 respectively while entering the switch ingress interface, which may cause for packet drop, but here i am able to ping.
One observation : if I extend Vlan 10 to other end switch (second switch) interface it wont ping and i do have Vlan10 in database which make sense, were in a single L2 switch we can have max of one active SVI..
 duplex full
 speed 100
end
Success rate is 0 percent (0/7)
Hi,One observation : if I
"then is it take default vlan and communincate each other ????" - not sure about this
"One observation : if I extend Vlan 10 to other end switch (second switch) interface it wont ping and i do have Vlan10 in database which make sense, were in a single L2 switch we can have max of one active SVI.". -  PING will fail because while going back it  comes from access port VLAN20 and it is still tagged  with VLAN 20   but  port fa 1/1 (VLAN 10) on same switch #4 will drop it due to VLAN mismatch
137
