Compatible WIC1 DSU T1 with 2651XM?
I am trying to add a WIC1 DSU T1 which uses an RJ connector to this router.
The card does not "power up" when the router is booted and is not seen by the IOS.
I removed a WIC1 DSU 56k, and two WIC T1's from this router before attempting go install the T1 WIC.
I have two cards to test with and neither seems to "light up" when the router is powered, and consequently not seen by the IOS.
Help? I need a compatibility matrix and also a command line configuration steps doc for the install.
This is sho ver:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(24), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 28-Apr-04 15:30 by kellmill
Image text-base: 0x8000808C, data-base: 0x8111AE9C
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
usca-sjc-403 uptime is 0 minutes
System image file is "flash:c2600-is-mz.122-24.bin"
cisco 2651XM (MPC860P) processor (revision 0x100) with 125952K/5120K bytes of me
mory.
Processor board ID JAD0626C7S5 (1809622083)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
1 ACCEPTED SOLUTION
Re: Compatible WIC1 DSU T1 with 2651XM?
on the 2600XM the min version of IOS which supports this card is 12.2(8)T1 and above you have 12.2 Mainline, move to a later T train or 12.3 Mainline.
Hall of Fame Super Bronze
Compiled Wed 28-Apr-04 - you have a code that is almost 4 years old. Give it an upgrade and the module will work.
HTH,
__
Edison.
Thank you,
I have upgraded to 12-2.8.T5 and it is working.
Thank you very much.
Paul
156
