06-16-2009 12:29 PM - edited 03-04-2019 05:08 AM
hi
I have a configuration file of 70KB size but on my router I only 55KB nvram.
is there a way to compress the configuration.
06-16-2009 12:42 PM
conf t
service compress-config
use the search, these things are easy fo find.
06-16-2009 02:10 PM
thanks for your reply
I have under question
can I use my carte flash instead of my NVRAM because I have a large file.
if yes tell me how.
thanks.
06-16-2009 02:55 PM
Try compress first, it's much easier and very effective.
06-17-2009 09:48 AM
habaoui
I am not sure if it is model dependent or IOS version dependent, but I tested using the compact flash card to store the startup config and it worked well. I was testing on an 1841 running 21.4T.
Rick
06-17-2009 11:28 AM
Hi Rburts
can you give me the link or config
thanks
06-16-2009 04:56 PM
Try
1- service compress-config,
2- copy running-config startup-config command
06-17-2009 12:43 PM
I have done this but the following message appear:
Uncompressed configuration from 52150 bytes to 201331 bytes
