Compression Card AIM0 is not Compatible with Cisco 3825
Guys,
I have Cisco 3825 having some compatibility problem with its AIM0 slot. I m gonna use hardware compression card i.e AIMR-V2. This card was working with Cisco 2811. Now i moved this to Cisco 3825. After putting it into Cisco 3825 router, card is detecting by the router but AIM0 LED showing Amber light. Which shows the Incompatibility. When i check the SH VER and SH DIAG , there is no Card installed. In my SDM, I am getting the Error of compatibility.
If any one idae.,than revert back
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Compression Card AIM0 is not Compatible with Cisco 3825
Which IOS did had on the 2811, and which do you have on the 3825 ?
THere are 2 AIM slots in a 3825. Can you try installing the same on the other slot and check?
Narayan
Yes I tried with both AIM slots. Not workign on both slots.
Let me check the compatibility chart also.
415
