Community Member
concurrent routing and bridging
I have a router that has 2 ethernet and 2 serial interfaces. Those are distinguished into pairs(1 ethernet + 1 serial) and I wish one pair to do ip routing, and the other one to do concurrently both osi clns routing and ip bridging. Is this possible? Might the irb feature be a solution in my case?
Thank you in advance.
Panagiotis.
1 REPLY
Hall of Fame Super Bronze
Re: concurrent routing and bridging
Yes, IRB (Integrated Routing and Bridging) will work on this scenario.
681
