Conditional default route - RIP
I am tring to inject a default route in RIP v2 with a condition of only if
Int Loopback0 up
int loopback 1 down
Now i can successfully do this with any FAKE route other than 0.0.0.0 , when i use 0.0.0.0 it initally works until the the loopback1 interface is enabled and then shutdown again to meet the boolan condition.
R3 config:
track 3 list boolean and
object 1
object 2 not
interface Loopback0
ip address 3.3.3.3 255.255.255.0
interface Loopback1
ip address 33.33.33.33 255.255.255.0
shutdown
track 1 ip route 3.3.3.0 255.255.255.0 reachability
track 2 ip route 33.33.33.0 255.255.255.0 reachability
ip route 0.0.0.0 0.0.0.0 Null0 track 3
ip prefix-list Null permit 0.0.0.0/0
router rip
version 2
network 10.0.0.0
default-information originate route-map default
no auto-summary
route-map default permit 10
match ip address prefix-list Null
R3#sh track
Track 1
  IP route 3.3.3.0 255.255.255.0 reachability
  Reachability is Up (connected)
    1 change, last change 00:43:39
  Delay up 2 secs, down 2 secs
  First-hop interface is Loopback0
Track 2
  IP route 33.33.33.0 255.255.255.0 reachability
  Reachability is Down (no route)
    17 changes, last change 00:14:06
  First-hop interface is unknown
Track 3
  List boolean and
  Boolean AND is Up
    30 changes, last change 00:14:06
    object 1 Up
    object 2 not Down
  Tracked by:
    STATIC-IP-ROUTING 0
R1#sh ip route rip | in 0.0.0.0/0
R2#sh ip route rip | in 0.0.0.0/0
Fake route other than 0.0.0.0
R3#
ip route 100.100.100.100 255.255.255.255 Null0 track 3
ip prefix-list Null permit seq 5 100.100.100.100/32
R*   0.0.0.0/0 [120/1] via 10.1.234.3, 00:00:06, FastEthernet0/0
R*   0.0.0.0/0 [120/1] via 10.1.234.3, 00:00:15, FastEthernet0/0
what am I missing, or not referancing here?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
if I redistribute the static default pointing to null0 and track this route then it works:
R1(config-if)#do sh run | s ip route|track|route-map|ip prefix|router rip
track 1 interface Loopback0 line-protocol
track 2 interface Loopback1 line-protocol
object 1
object 2 not
router rip
version 2
redistribute static route-map DEFAULT-ROUTE
network 10.0.0.0
default-information originate route-map DEFAULT-ROUTE
no auto-summary
ip prefix-list test seq 5 permit 0.0.0.0/0
route-map DEFAULT-ROUTE permit 10
match ip address prefix-list test
route-map DISTR permit 10
match interface Null0
Alain
cadet alain
this is what I did and it works:
R1(config-if)#do sh run | s ip prefix|route-map|track|router rip
object 1
object 2 not
router rip
version 2
network 10.0.0.0
no auto-summary
ip route 169.254.0.0 255.255.0.0 Null0 track 3
ip prefix-list test seq 5 permit 169.254.0.0/16
Alain
Hello
Thanks for the reply -
I also  get the same result with any FAKE route I use, APART from when try using
res
Paul
Thanks.
Kind Regards
Paul
object 1
object 2 not
router rip
version 2
network 10.0.0.0
no auto-summary
Alain
Hello
It indeed does -..NOW looking back at my config I also tried redistribute the static route-map but my reference to the route-map was wrong!
instead of defaulti was referencing Default -hence I concluded that didn't work either.
Appreciate the assistance
res
Paul
Thanks.
Kind Regards
Paul
