Community Member
Conencting E1 circuit with regular Ethernet cable
Hi guys,
Have you ever had problems when connecting E1 circuit with regular Ethernet straight-through cable (4 twisted pairs instead of 2)?
The router is at a remote location and I cannot change the cable.
Router type: cisco 2800.
E1 controller is up; serial is up, line protocol is down.
I believe the problem is not in the cable but I checked the configuration and there is no issue as well.
Darko
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Conencting E1 circuit with regular Ethernet cable
1. Alway use properly wired and twisted T1 cable using T1 pinout.. DO NOT USE ETHERNET CABLE.
2. this said, problem can be in the circuit and not in the cable. Send "show controllers E1" and "show interface serial".
Note: even if the SP swears the circuit is working, that is oftent NOT the case.
Community Member
1. I totaly agree with this. However since the cable is already there I asked if anyone ever had an issue like this caused by the Ethernet cable.
2. Router is not operational now. Therefore I cannot send the "show controllers E1" and "show interface serial" output. My client told me they will change the E1 module and then call me to check it again.
It is a waste of time and money to replace hardware.
When a circuit does not come up, the problem is in the circuit, not in the router. Always.
Thank you for the nice rating and good luck!
633
