conf ISDN PRI OK with 2621 but don't work on 28XX
HI,
I have read previous mesage and haven't found a answer of my problem.
I have a problem of connexion on PRI.
When I use a 2621 with this conf, it work fine:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-16
interface Serial0/0/0:15
no ip address
encapsulation ppp
dialer pool-member 23
isdn switch-type primary-net5
ppp authentication chap
ppp multilink
interface Dialer23
ip address X.X.X.2 255.255.255.0
encapsulation ppp
dialer pool 23
dialer remote-name REMOTE_SITE
dialer fast-idle 240
dialer string XXXXXXXXX
dialer-group 1
no cdp enable
ppp multilink
dialer-list 1 protocol ip permit
when I use the same on 28XX, there is no communication
boot system flash c2800nm-ipbase-mz.123-11.T7.bin
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
<removed>
controller E1 0/0/0
framing NO-CRC4
no ip address
encapsulation ppp
isdn incoming-voice data
ppp multilink
interface Dialer23
ip address 10.101.123.2 255.255.255.0
encapsulation ppp
dialer pool 23
dialer-group 1
no cdp enable
ppp multilink
_______________
I have the following output
%CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
Feb 6 09:58:49.477: ISDN Se0/0/0:15 SERROR: service_queue_from_physical_layer: got ISDN_PH_ACT_IND on an active interface?
Feb 6 09:58:51.477: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to up
Feb 6 10:01:54.695: ISDN Se0/0/0:15 SERROR: isdn_get_guid: Cannot allocate a GUID (5).....
Is there anybody has a idea of the cause of this problem.
What mean "Cannot allocate a GUID" and "ISDN_PH_ACT_IND"?
thank you for your help
160
