Config AIM-ATM-4E1 plus NM-1A-E3 on Cisco 3845 router
Hi Sir,
I am config a Cisco 3845 router ios version 12.3(11r)T2. This router current have a AIM-ATM-4E1 connect to WAN. When I plug in the card NM-1A-E3 into the router. The E1 connection will lose (ATM0/IMA0 will up and line protocol will up but the pvc cannot active) even the E3 card still not be config anthing. How can I make this two card work properly in to the router? This is the current config in the E1 card in router.
controller E1 0/0/0
mode atm aim 0
controller E1 0/0/1
mode atm aim 0
controller E1 0/1/0
mode atm aim 0
controller E1 0/1/1
interface ATM0/IMA0
bandwidth 6144
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
load-interval 30
ntp disable
atm vc-per-vp 1024
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
interface ATM0/IMA0.222 point-to-point
bandwidth 3000
ip address 1.1.12.1 255.255.255.252
ip access-group 135 in
ip access-group 135 out
pvc att-per 1/222
vbr-nrt 5760 5760
oam-pvc manage 0
encapsulation aal5snap
max-reserved-bandwidth 100
interface ATM0/0/0
bandwidth 2048
no ip address
scrambling-payload
ima-group 0
no atm ilmi-enable
interface ATM0/0/1
bandwidth 2048
no ip address
scrambling-payload
ima-group 0
no atm ilmi-enable
interface ATM0/1/0
bandwidth 2048
no ip address
scrambling-payload
ima-group 0
no atm ilmi-enable
Thank you
1 REPLY
Bronze
Re: Config AIM-ATM-4E1 plus NM-1A-E3 on Cisco 3845 router
Hi ,
Try to put the new card in some other slot .
I faced a similar problem with Cisco 7200 , But I don't know what's going exactly with your config . It's saying that there is 2 Bus Left side Bus1 (Slots 1, 3, 5 ) and right side Bus 2 ( (slots 2, 4, and 6) and cisco is recommending to distribute port adaptor evenly a across left and right slots (buses )
http://www.cisco.com/en/US/docs/routers/7200/configuration/7200_port_adapter_config_guidelines/3875In.html#wp1061412
?Haris
339
