Config commands for T1 services turn-up 2811?
jmrosenfeld
Greetings,
I could use some assistance figuring out the config commands for turning up a GC 384kbps T1 using a cisco 2811 router. Sorry, I'm a newb who isn't completely sure of the neccessary config commands to complete the turn-up and T1 configuration. Any help would be appreciated. An edited version of the routers relevant config is below.
This router has a T1/PRI dual port WIC and was previously setup to use an old T1 and PRI both of which have been disconnected. (configuration for the old connections is still in the config) I wil only be turning-up the data T1 for the first port in the dual port WIC and not a PRI.
! Last configuration change at 08:53:38 UTC Fri Sep 8 2006
! NVRAM config last updated at 10:40:37 UTC Mon Aug 14 2006
version 12.4
service password-encryption
service sequence-numbers
hostname XXXXXXXX
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
resource policy
clock timezone UTC -6
clock summer-time UTC recurring
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
-config removed for briefity-
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-12,24
controller T1 0/2/1
framing esf
linecode b8zs
interface Loopback0
ip address 192.168.254.1 255.255.255.0
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ETH-LAN$
ip address 10.0.5.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.0.5.1
interface FastEthernet0/1
description $ETH-WAN$
ip address 192.168.2.9 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip address XXX.XX.XX.XXX 255.255.255.252
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.0.5.15
ip route 192.168.10.0 255.255.255.0 10.0.5.2 200
The new T1 should use the same signaling and framing (B8ZS/ESF) and the network uses OSPF area 1. I'm assuming that all I would need to do is have someone plug the T1 connection into the proper T1 port on the dual T1/PRI WIC card, change the serial 0/0/0 ip to the proper internet ip, set the bandwith value on the S0/0/0 and configure ospf with
router ospf 1
network serial ip reverse mask
network internal network ip reverse mask
Am I missing anything?
Thanks.
Jon
5 Replies 5
smothuku
Level 7
Level 7
Hi ,
If you want to use ospf in your network then it should be connected to area 0..let assume that your ip belongs to area 0 and your network is in area 1 then config look likes..
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-31 speed 64
ip address x.x.x.x
encapsulation hdlc
bandwidth 2048
router opsf 1
network x.x.x.x wildcard area 0
network x.x.x.x wildcard area 1
you can use nat for translating inside ip's to public ip's and access-list for controlling no.of ip's for accessing internet.
satish
Thanks for the help.
My fault, I checked other router configs and they are all in ospf area 0. I mistook the process id in the command router ospf 1 for the area.
Does the serial connection encapsulation default to hdlc? A T1 worked previously without specifying the encapsulation. This will be the same type of GC managed MPLS IP vpn connection that it had previously, it won't be able to connect directly to the internet per se, just our private network, all internet traffic is routed out one connection.
hi ,
Default encapsulation for serial is hdlc.If you change the encapsulation then you can use "encapsulation PPP " under serial interface.
satish
Gotcha.
All of our routers should be in ospf area 0.
After I change the serial IP to the new IP and configure ospf with
router ospf 1
network new public T1 ip inverse subnet mask area 0
network internal ip inverse mask area 0
then should I be all set?
pciaccio
Level 4
Level 4
Jon:
I'm not sure if I am reading this correctly or not, but you state that this line is not an ISDN PRI. However your config shows timeslots 1-12 and 24. If this is not an ISDN line anymore then you will not need the 24th timeslot. Assuming that the 384k are laid out in the first 8 timeslots of 64k then you need to remap your DS0's for the T-1. If not then you need to get with your provisioner and verify the timeslot mappings. You will need to remove the PRI timeslot command and replace with channel group command for the controller. Also for the serial interface you need to remove all ISDN related commands. The default encap is HDLC for a serial link. Please respond with further questions we will assist you further...Phil
