06-15-2012 06:01 AM - edited 03-04-2019 04:41 PM
for point to pint network i use privateip and i use two link thus the config for etherchannel works
My requirement there are 2 link so can i bundled with etherchaanel
0n l3 switch(switch1)
int po1
no switchport
ip address 172.18.2.1 255.255.255.0
no shutdown
int range fa0/1-2
no switchport
switchport access valn 199
channel-group 1 mode on
on fa0/1--isp1 link
on fa0/1---isp2 link
ip route 0.0.0.0 0.0.0.0 172.18.2.2
on l3 switch(switch2)
int p01
no switchport
ip address 172.18.2.2 255.255.255.0
no shutdown
int range fa0/1-2
no switchport
switchport access vlan 22
on fa0/1-isp1 link
on fa0/2-isp2 link
ip route 0.0.0.0 0.0.0.0 172.18.2.1
06-15-2012 06:26 AM
Hello Prashant,
I recommend to use LACP instead of unconditional bundling it provides the capability to detect the neighbor and that is the same system connected to the other link.
You have ISP connections in the middle and so it is important to bundle in a safe way.
So I would use
channel-group 1 mode active
in order to use LACP. LACP messages are sent over every member link.
Another point of attention is that you are configuring each multilayer switch with a static default route to the other device and this is not good practice.
If you know that one site is more important you can configure the static default route on the other router, but on the main site you should configure specific static routes describing the IP subnets that are reachable at the other site.
Hope to help
Giuseppe
06-15-2012 07:03 AM
Thanks for valuable suggestion.I will use lacp .
If I create svi on switch 1 such as
int vlan 21
ip add 192.168.100.1
Now on switch 2 if i give
ip route 192.168.100.0 255.255.255.0 172.18.2.1(ie p01 ip address) Thus it work.
Is my above config right ?
06-15-2012 07:14 AM
Hello Prashant,
your configuration is right
yes this is what I was meaning on the main site you build specific static routes for the client IP subnets of the other site.
you can actually also use an aggregate covering multiple IP subnets with a single static route, but the idea is to avoid to have each site using a default route pointing to the other one.
Hope ot help
Giuseppe
06-15-2012 07:29 AM
Thanks a lot
The think is I have implemented ether channel with in site using lan links.
But not between diffrent sites using wan links.
11-25-2014 01:12 AM
can somebody come up with results ?
