Config file was not reloading properly from FTP on ME 3600x with SFP module, after rebooting
I have an issue with ME 3600x switch with SFP,
Here my explanation
I replaced 4506 switch with new ME 3600x with SFP Module
Once i've replaced with new switch ME 3600x..after i copied config file from FTP into ME 3600x then switch got rebooted.
NOTE : Config file was pre-desinged by my Sr.Network Eningneer and copied into FTP server
After rebooted i logged into the device and i've seen some files didn't copy(AAA,SNMP,TACACS )...i tried twice then it was reloaded with new config file.
Can somebody let me know what was the issue
Here I have another issue with config file of ME 3600x with SFP
Once i copied config file...i have seen every interface configured as "Port-type nni"
But it should be "Switchport mode access"
Can't we change Port-type nni to Switchport mode access...it means convert into NNI into UNI
NOTE: My ME 3600x with SFP supports only Port-type nni, when i type command "Port-type ?" it shows only NNI
Still bothe switch are working with NNI type however still i haven't yet get any issue
Message was edited by: Sivakanth Akkapu
Reza Sharifi
Not all commands between 4500 and 3600x are the same.  You need to take a portion of the config and loaded it to your 3600x and watch for error messages. Than fix the error massages and copy and paste some more.  You probably need to redo some commands all together.
As for your question on switch port mode type.  On the inteface first try to set the interface to switch port and than type access.
config t
inter gi1/0/1
switchport
switchport mode access
Hi Reza,
I didn't get any error message....it's copied successfully after rebooted the switch
i've seen some config files were missing on switch ( AAA,TACACS,SNMP configuration)...
i copied manually those commands into switch...then it worked..
i configured switchport mode access manually to the interfaces but it doesn't work
still all interfaces are configured as "Port-type mode nni"
I am suspecting, is there any extra things which we do while config with SFP module
Please let me know what was root cause for this problem.
Could you someone please explain this problem...
