06-10-2012 09:59 PM - edited 03-04-2019 04:38 PM
As per as scenario router 2 and router 4 are the routers which are located in my comapny.
Router 2 is active router and router 4 is the standy router.Router 0 and router 5 are isp router
My requirement is that the packet which are going out ofmy network should go from Router 2.
And packet coming from isp to my network should come via Router 4.
I have implemented As path prepend on router 2 so that packet comming from isp should come from Router 4.
What happens if i donot create ibgp neighbourship betwen router 2 qnd router 4?
Please let me know if the config is correct or any changes need to be done ?
router2#show running-config
Building configuration...
Current configuration : 604 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname router2
interface FastEthernet0/0
ip address 172.18.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 101.177.157.38 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router bgp 54xxx
bgp log-neighbor-changes
no synchronization
neighbor 101.177.157.37 remote-as 9999
neighbor 172.18.2.2 remote-as 54xxx next-hop-self
neighbour 101.177.157.37 route-map rsap out
network 172.18.0.0
ip classless
interface fa0/0
standy 1 priority 200
standy 1 ip 172.18.2.10
standy 1 prempt
standy 1 track fa0/1
access-list 1 permit 172.18.2.0
route-map rsap permit 10
match ip address 1
set as-path prepend 100 100
line con 0
line vty 0 4
login
end
Router4 configuration
router4#show runn
router4#show running-config
Current configuration : 608 bytes
version 12.4
hostname router4
ip address 172.18.2.2 255.255.255.0
duplex auto
speed auto
ip address 102.177.157.43 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router bgp 54xxx
no synchronization
neighbor 102.177.157.41 remote-as 8888
neighbor 172.18.2.1 remote-as 54xxx
neighbor 172.18.2.1 next-hop-self
network 172.18.2.0
int fa0/0
standby 1 ip 172.18.2.10
standy 1 priority 150
standy 1 preempt
ip classless
line con 0
line vty 0 4
login
end
06-10-2012 11:36 PM
Hi Prashant,
Your requirement as i understand is :-
1) To influence the outbound traffic to take R2.
2) To influence the inbound to take the path via R4.
Now, to prefer an ISP for outbound you need to set a higher local preference to the neighbor. So, that downstream traffic takes R2 to R0 path.
To prefer an ISP for inbound, you have done it correctly using AS-path Prepending.
Question of iBGP being required. I would say "yes". Because if the primary path was to fail, downstream devices would not know where to forward the request. HSRP tracking might be enabled for interface, nowadays it's all ethernet so the chances to the connected interface going down is rare. You may need to think of running IP SLA along with it to get this working else.
If you were to run iBGP between R2 & R4, then you have no such issues. Assume that the path from R2 fails, you would have another path via R4. Still the packets will be forwarded to the Active router (i.e R2) & based on the BGP table it knows the next-hop is via it's iBGP peer. It simply forwards.
Hope this helps.
Vivek
06-10-2012 11:50 PM
hi,, dear...
i show ur configuration... just configure there inbound and outbound... when ur packet go out side there configure outbound means data out ack in and where u want to receive ur packet that side configure inbound means data in ack out.... and u need to configure ibgp for backup path or ur internal router communication .. hope this is needful
06-11-2012 01:05 AM
hi vivek,
Thanks a lot
THe think if the link on active router it is taking too much to converge.
If i create ibgp neighbour it might not take too much og time right ?
I have created local prefrence below is the direction right ? ie in or out.
router bgp 54xxx
neighbour 101.177.157.37 remote-as 9999
neighbour 101.177.157.37 route-map rsa in
ip prefix-list default seq 5 0.0.0.0/0
route-map rsa permit 10
match ip prefix-list default
set local-prefence 600
06-11-2012 01:10 AM
You are right. Using iBGP will improve your convergence. Local preference needs to be applied in "inbound direction" & you have done it correctly.
06-11-2012 01:46 AM
hi vivek
I have congigured sla for the wan link on active router .But the wan link and lan linl was up only. suddenly standy become
active router.Does sla have any disadvnatage does frequency whic i have given have any eefect? please find the logs and config
of sla
Jun 11 06:00:47.571: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Active -> Speak
Jun 11 06:00:50.351: %TRACKING-5-STATE: 123 ip sla 1 reachability Down->Up
Jun 11 06:00:52.907: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Speak -> Active
Jun 11 07:28:13.830: %TRACKING-5-STATE: 123 ip sla 1 reachability Up->Down
Jun 11 07:28:14.642: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Active -> Speak
Jun 11 07:28:18.830: %TRACKING-5-STATE: 123 ip sla 1 reachability Down->Up
Jun 11 07:28:20.250: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Speak -> Active
Jun 11 07:29:03.870: %TRACKING-5-STATE: 123 ip sla 1 reachability Up->Down
Jun 11 07:29:05.986: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Active -> Speak
Jun 11 07:29:08.870: %TRACKING-5-STATE: 123 ip sla 1 reachability Down->Up
Jun 11 07:29:11.458: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Speak -> Active
Jun 11 07:29:53.910: %TRACKING-5-STATE: 123 ip sla 1 reachability Up->Down
Jun 11 07:29:54.506: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 1 state Active -> Speak
ip sla 1
icmp-echo 101.177.157.37
threshold 2000
frequency 10
ip sla schedule 1 life forever start-time now
track 123 ip sla 1 reachability
standby 1 track 123
06-11-2012 07:15 PM
Your config looks ok. I have seen a similar issue with my own setup with IP SLA, it keeps dropping off without any genuine reason. I would suggest to avoid this feature (my personal opinion). Using iBGP would be a more viable solution for this scenario.
06-11-2012 08:52 PM
From firewaall i have default route to virtual ip.
If i do ibgp it might create a problem ?
when i do show ip route there is a default route to isp with hop of neigh ip.
shall i implemet object tracking instead of ibgp?
If i remove ipsla does it work smootly ?
