Community Member
Config not saving on router
I have a 2821 router and is trying to configure it. the problem is, whenever i reboot the router, it starts with the setup dialog and no startuo-config file on flask
Of course I save before rebooting.
Please help
Re: Config not saving on router
Asib,
Check the config-register. It is probably not set to 0x2102. You can check the config-register by issuing a "show version". To change it do:
router(config)# config-register 0x2102
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
totally forgot about that...Thank you
137
