config-register setting advice
I have a Cisco 3845 with a Configuration register set as 0x2102.
A boot variable set to:
boot-start-marker
boot system flash c3845-advipservicesk9-mz.124-22.T.bin
boot system flash c3845-advipservicesk9-mz.123-14.T6.bin
boot-end-marker
and a flash file with the following:
1 -rw- 32232640 Nov 29 1983 23:00:00 -06:00 c3845-advipservicesk9-mz.123-14.T6.bin
9 -rw- 59161972 Oct 21 2008 14:01:02 -05:00 c3845-advipservicesk9-mz.124-22.T.bin
I want to boot to 12.4T first and if that fails boot to 12.3T. With my current setting every time I reboot the router it boots 12.3T. I know this is most likely a problem with my Configuration register set wrong, but I do not know what to change it to.
Please advise - Many thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: config-register setting advice
Your config register looks okay. What do you see on the console when you reload the router ie. does it say it cannot find specified file. Assuming internal flash is the location of these images try
boot system flash flash:c3845-advipservicesk9-mz.124-22.T.bin
boot system flash flash:c3845-advipservicesk9-mz.123-14.T6.bin
Jon
Jon
That did it - Thanks for the help!
537
