10-11-2006 10:57 AM - edited 03-03-2019 02:19 PM
El router 1811 soporta conexion ADSL?
Solved! Go to Solution.
10-11-2006 12:58 PM
10-11-2006 12:58 PM
10-12-2006 04:54 AM
Pero si el Router no tiene interface ATM, como seria un ejemplo?.
10-12-2006 11:27 AM
?Usted tiene un WIC-1ADSL ahora que no est? trabajando? Si un WIC-1ADSL ahora est? en su rebajadora, y usted no ve un interfaz de la atm?sfera, fije por favor una "show version".
10-12-2006 06:54 PM
soporta pppoe o sea necesitas conectar un modem adsl por ej cisco 677 y de ahi conectas por ethernet al fe 0 o 1 y configuras pppoe en esa interfaz.
10-13-2006 05:00 AM
Queria Compratir esta configuracion exitosa de ADSL.
!This is the running config of the router: 192.168.1.1
!version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxx
enable password consola
no aaa new-model
resource policy
clock timezone Buenos -3
ip cef
no ip domain lookup
interface FastEthernet0
description ADSL01$ETH-WAN$
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip nat inside
ip virtual-reassembly
interface Vlan2
interface Async1
no ip address
encapsulation slip
shutdown
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
ppp authentication pap callin
ppp pap sent-username xxxxxxxxx password 0 xxxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.1.2
dialer-list 1 protocol ip permit
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
