Configuration guidelines for Cisco871-K9 Model
ashley1234
I'm a novice having difficulty with configuring my 871 router with the virgin network on a cable modem. If anyone can give me a set of guidelines for this I'd be grateful.
50 Replies 50
paolo bevilacqua
Post actual configuration and someone may have it corrected for you.
Mark Yeates
Level 7
Level 7
Ashley,
Here is a configuration guide for the 850/870 series routers. Just like Paolo said that if you post the config we would be glad to help you.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
Mark
Thanks a lot, Mark, a section of the config file is here, if you need more let me know. As you can see the clock is wrong for a start. I'm not sure whether to configure the router as dns server or use the virgin dns servers 62.253.162.237 and 194.168.4.237. ? also the question of static or dynamic routing? I have previously used a mercury K0B RI00 router which works fine on the dynamic/cable modem setting, I will include these settings in case it's useful.
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 10.10.10.1
default-router 10.10.10.1
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 192.168.1.10 255.255.255.0
ip access-group 101 in
ip verify unicast reverse-path
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 23
logging trap debugging
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Here are the settings for the Mercury router which works fine -
Connection Type Dynamic IP
WAN IP 82.22.8.84
Subnet Mask 255.255.252.0
Gateway 82.22.8.1
DNS 62.253.162.237
Secondary DNS 194.168.4.237
LAN
IP Address 192.168.1.1
Subnet Mask 255.255.255.0
DHCP Server Enabled
Firewall Enabled
INFORMATION
System Time 2008/05/24 09:03:23
System Boot Up Time 00007 days 22:40:22
Connected Clients 0
Runtime Code Version V2.00.0096
Boot Code Version V2.00.34
LAN MAC Address 00-40-F4-FD-B8-A8
WAN MAC Address 00-40-F4-FD-B8-A9
You configure:
dns-server 62.253.162.237 194.168.4.237
int fa4
ip address dhcp
no ip access-group 101 in
no ip verify unicast reverse-path
no ip inspect DEFAULT100 out
no ip route-cache flow
int vlan1
no access-group 100 in
no ip tcp adjust-mss 1452
no ip http server
no ip http secure-server
no ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 23
ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 230
no ip route 0.0.0.0 0.0.0.0 fa4
access-list 1 permit 10.10.10.0 0.0.0.255
That should get you going. To telnet from outside to your .2 device, telnet to the address of the router, port 230. The route can also use Dynamic DNS so you always know which address it got.
Hope this helps, please rate post i it does!
Thanks very much, will get back to you on this...
Configured as requested, but must be doing something wrong somewhere as there is still no internet connectivity. The ethernet cable to my pc is on f3 by the way.
Please have a look at the current configuration and advise what to do next.
Thanks!
Building configuration...
Current configuration : 3727 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp excluded-address 10.10.10.249 10.10.10.254
import all
ip name-server 62.253.162.237
ip name-server 194.168.4.237
no ip address
duplex auto
speed auto
interface Vlan1
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Ashley,
You will need to implement NAT (Network Address Translation) on your router to be able to access the internet on the inside of your network. Please input the following lines into your router.
access-list 1 remark NAT_ACL
ip nat outside
interface Vlan1
ip nat inside
This will allow you to utilize all four switchports.
Mark
Done, but still no connection. I note that in SDM
the WAN type is unsupported and has no ip address. Here is the latest configuration:
Current configuration : 3910 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
import all
no ip address
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Do you have an NTP server on your network? I usually recommend the use of a NTP server to synchronize the clock on the router. I use a public server for my home equipment. Feel free to use the below statements to update the time on your router.
ntp server 207.46.130.100 source FastEthernet4 prefer
ntp server 192.43.244.18 source FastEthernet4
and these for your appropriate timezone.
clock timezone Central -6
clock summer-time CDT recurring
If there is anything else you need help with let us know.
Mark
Much appreciated, will let you know how everything went.
Mark, configured the ntp server, but still no web access or net connectivity. Here is my current configuration, can you tell me what's wrong?
I can post ipconfig /all results from the pc command line if you need it.
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
import all
no ip address
duplex auto
speed auto
interface Vlan1
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Please review my configuration above, you're mssing "ip address dhcp" and many other commands.
I've re-entered all the commands in your list, and I see that the WAN interface in SDM is unsupported, there is no ip address. Where do I go from here?
also, should I configure default gateway and gateway of last resort, and if so, how?
Ashley
