Webcast-Catalyst9k
Configuration of Network Capacity Expansion Service Module
Hi!
Routers A and B have been configured and connectivity between the two sites is ok.
The users at Site B are able to access the server hosted at Site A using https.
However, both routers are equipped with an AIM-TPO-1 NCE service module.
These modules are standalone transport-optimization engines having their with own startup and run-time configurations.
The Transport-Opt-Service-Engine slot/port can be configured with an IP address and the following configurations are also required:
  • service-module ip address
  • service-module ip default-gateway
Should the module on both routers A and B be configured for the communication to be successful?
Is the access to the server faster when using the AIM-TPO-1 module?
Is there a limit to the number of transactions the AIM-TPO-1 can handle?
Please see attached files.
Alvin
169
