Configuration of VWIC-2MFT-E1 between two routers
Hi there,
I have two Cisco 2851 routers each with a VWIC-2MFT-E1 module. What kind of cable should I use to connect them point-to-point in a close distance and if possible any working configuration.
Klean...
Re: Configuration of VWIC-2MFT-E1 between two routers
You need to reverse the pin outs on the other end connecting to the router.
Normally the signal comes on 1,2 & 4,5 pairs ,one side you keep this and on the other side you just reverse the same which i feel should work..
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
regds
Yes a back to back T1/E1 cable works
1--4
2--5
HTH, rate if it does
Narayan
Bronze
You need to use cross cable , with pin detail are below
1--4
2--5
4--1
5--2
if i am recall correctly , 1&2 are RX and 4&5 are TX.
-Minu
please rate this post.
290
