Configure FTP on Port 990
jjcomp
I currently have a Cisco 891 running with a FTP running on port 21. I currently have the NAT from external IP to and internal IP 192.168.12.6 for port 21. And the firewall allowing that traffic through and client software is working fine. However I need this FTP to be running on port 990 and anytime I change the NAT and the firewall, the external FTP clients connect but then drop when recieving the directory listing.
Any help would be greatly appreciated!
18 Replies 18
Jennifer Halim
I assume that you also have FTP inspection configured on the router. The reason why the directory listing drops the FTP connection is because you are using non standard port, and the FTP inspection by default only inspect control port 21, and it will automatically allow the data connection. Since you are using non standard port, then it is not inspected by the ftp inspection engine, hence is dropped.
You can configure port map for FTP control to port 990, and inspect ftp, however it will only inspect 990, and if you have any other FTP connection on standard port 21, it will not be inspected, and data connection will be dropped.
I believe I tried that and it didn't work.... Can you give me an example?
I tried....
ip nat inside source static tcp 192.168.12.6 990 interface FastEthernet8 990
ip nat service list 10 ftp tcp port 990
access-list 10 permit 192.168.12.6
I have also tried:
ip port-map ftp port 990 list 10
do you also have inspect ftp configured?
can you please share your current configuration.
This is my current config with it running on port 21....  Over the past 24 hours I have tried all kinds of things but no sucess...  I've got to be missing something small, but what it is I'm not sure.  I believe this does have a section were ftp is being inpected via
class type inspect sdm-nat-ftp-1
  inspect
Thankyou in advance for any help!  This is driving me crazy.
__________________________________________________________________
Building configuration...
Current configuration : 11716 bytes
! Last configuration change at 22:14:11 PCTime Wed May 23 2012 by XXXXX
! NVRAM config last updated at 23:15:29 PCTime Wed May 23 2012 by XXXXX
version 15.0
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 X
no aaa new-model
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-X
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-X
revocation-check none
rsakeypair TP-self-signed-X
crypto pki certificate chain TP-self-signed-X
certificate self-signed 01
  X
       quit
ip source-route
ip gratuitous-arps
ip dhcp excluded-address 192.168.12.1 192.168.12.199
ip dhcp excluded-address 192.168.12.254
ip dhcp pool ccp-pool1
   import all
   network 192.168.12.0 255.255.255.0
   default-router 192.168.12.1
   dns-server 192.168.12.1
ip cef
ip domain name yourdomain.com
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip port-map user-protocol--1 port tcp 2080
no ipv6 cef
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
license udi pid CISCO891W-AGN-A-K9 sn FTX1530806W
username XXXXX privilege 15 secret 5 X
ip finger
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 102
match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-all sdm-nat-ftp-1
match access-group 101
match protocol ftp
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address X.X.X.X 255.255.255.240
ip mask-reply
ip directed-broadcast
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface GigabitEthernet0
no ip address
ip mask-reply
ip flow ingress
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
ip mask-reply
ip flow ingress
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$
ip address 192.168.12.1 255.255.255.0
ip mask-reply
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
interface Async1
no ip address
ip mask-reply
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet8 overload
ip nat inside source static tcp 192.168.12.50 2080 interface FastEthernet8 2080
ip nat inside source static tcp 192.168.12.6 21 interface FastEthernet8 21
ip route 0.0.0.0 0.0.0.0 X.X.X.X
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.12.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 209.60.166.192 0.0.0.15 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.12.6
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.12.50
no cdp run
control-plane
banner exec ^CCCC
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username  with the username and password you want to
use.
^C
banner login ^CCCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin udptn ssh
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
You're trying to use FTP over SSL (aka FTPs) which is not supported by the ASA:
https://supportforums.cisco.com/thread/2010303
I just need port 990 to act just like port 21....
access-list 101 should be configured with destination of FastEthernet8 interface instead of the private IP as it is inspected before NAT.
Jennifer,
Sorry but I'm confused on your response.... Isn't list 101 giving permission for the ip 192.168.12.6 to get the information from the NAT, just as list 102 is for the NAT on port 2080 for 192.16.12.50 (which is for a different service and server)? 101 should be referencing the outside-in traffic, if put in as FastEthenet 8 wouldn't that be telling it to that it has permission to send traffic to it's self.
I know that the way it is right now works for port 21. It's just getting this to work on port 990 instead of port 21 is we're I'm having the issue.
Both your NAT statements does not have access-list 101 or 102 applied to it:
Access-list 101 and 102 is actually applied to the Zone Based FW configuration within the class-map:
match protocol ftp
And because you are actually configuring static PAT on FastEthernet8 interface as per your NAT statement above, then the ACL should be matching FA8 ip address.
I'll give it a shot... Still confused...
After making that change, do I then need to apply the:
yes pls, and also:
Thanks.... I'll have to try it when I get back. I'll let you know what the results are.
