Configure SIP for 7600
Hello Experts,
If I have SIP-200 and I need to configure a feature , for eg - PPP on SIP-200 , is it something possible ? If Yes how I can do that in IOS ?
1 ACCEPTED SOLUTION
SIP-200 itself does support PPP:
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9df.html
However based on the line (cable) you have  you will further need to select SPA. E.G. there are T1/E1 SPAs available where you can directly connect serial line and the configure that for PPP.
E.G.
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a008043ff58.html
In case of optics you can install optical SPA and split SONEt into differnt tugs which can be later used as Serial lines over and optical channel.
E.G.
http://www.cisco.com/en/US/partner/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfstm1.html
Hope this helps.
Nik
1 REPLY
E.G.
E.G.
Hope this helps.
Nik
212
