11-13-2009 09:36 PM - edited 03-04-2019 06:42 AM
hi friends,
i am having broadband connection from my ISP .. it is RJ45 connection i need to configure this connection in 1841 router..
but the ISP given me username and password to get internet by dailing..
how i will configure using ethernt interface in cisco 1841 router.
11-14-2009 01:55 AM
Hello Cyril,
see this example
you don't need the vpdn part if your IOS is recent.
username and password has to be added to dialer interface configuration with commands like
int dialer 1
ppp authentication chap pap
you can configure username and password using
username xxx password yyy
in global config mode
Hope to help
Giuseppe
11-14-2009 09:42 PM
hi
i am using 1841 router and my interface cable is RJ45 cable not ADSL cable RJ11.
so i need to connect any one of the fast ethernet port in 1841 then how i can use dialer interface..
it is possible
11-14-2009 11:48 PM
Hello Cyril,
it is possible sorry for my misunderstanding
interface FastEthernet0/0
no ip address
speed auto
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
this links to dialer interface
interface Dialer0
ip address negotiated
ip access-group 105 in
ip mtu 1454
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1414
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp authentication pap callin
ppp chap hostname johnroche
ppp chap password pppoeisgreat
ppp chap refuse
ip route 0.0.0.0 0.0.0.0 Dialer0
on internal interface
int f0/1
ip address 192.168.11.250 255.255.255.0
ip nat inside
speed 100
full-duplex
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 192.168.11.0 0.0.0.255 any
Hope to help
Giuseppe
01-29-2017 10:36 PM
if i have a vlan in that wan connection how can configure pppoe
can you give guideline for me
09-18-2017 07:36 AM - edited 09-18-2017 07:43 AM
It's not a case since this is router's port not a switch port.
