Webcast-Catalyst9k
Configuring 0.255.0.255 as an inverse mask
All,
Just want to check that I understand this correctly.
You can configure an inverse mask like this, 0.255.0.255, right?
My understanding is that the "255" represents all 1's so in that case is allowed.
So used in an access list for example:
permit 10.0.3.0 0.255.0.255 would allow anything from 10.0.3.0 through 10.254.0.254?
Andrew
1 REPLY
Hall of Fame Super Gold
Re: Configuring 0.255.0.255 as an inverse mask
What you have done is a discontiguous mask. Their use is never recommended because these are counter-intuitive and everything done with them can be done with contiguous masks that are easier to read and understand.
558
