Configuring 2 T1's for voice
We have 2 sites connected with 2 Point to Point T1's and are looking for a good design to include voice. We originally had a multilink solution but Qos for voice was not working at all, so I tried to use static statements to point voice over one circuit and data over the other. Any design or functionality thoughts?
Running EIGRP with Cisco 2800 routers
Site A
interface Serial0/0/0
description Data T1
ip address 10.1.x.5 255.255.255.0
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no cdp enable
service-policy output VOICE-POLICY
interface Serial0/2/0
description Voice T1
ip address 10.1.x.6 255.255.255.0
encapsulation ppp
no ip mroute-cache
load-interval 30
no cdp enable
Site B
description Data T1
ip address 10.1.x.8 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
ip address 10.1.x.7 255.255.255.0
encapsulation ppp
no ip mroute-cache
load-interval 30
no cdp enable
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 (data)
ip route 172.x.30.0 255.255.255.0 Serial0/2/0 (Voice)
ip route 172.x.70.0 255.255.255.0 Serial0/2/0 (Voice)
ip route 172.x.80.0 255.255.255.0 Serial0/2/0 (Voice)
VIP Purple
Re: Configuring 2 T1's for voice
how did you configure your service policy ? Have a look at this configuration example, which can be used for Cisco VoIP traffic:
class-map match-all VoIP_Traffic
match access-group name VOICE_ACL
policy-map VOICE-POLICY
class VoIP_TRAFFIC
set dscp 5
class class-default
set dscp 1
access-list extended VOICE_ACL
permit tcp any any eq 1720
permit udp any any range 16384 32767
Apply this to all your serial interfaces with the command ´service-policy input VOICE_POLICY.
In addition, turn on CEF, and configure two equal cost default routes, which will ensure per-destination load-balancing over both T1s. So, putting this all together, your configuration should look like this:
Site A
ip cef
description Data T1
encapsulation ppp
no ip mroute-cache
no cdp enable
service-policy input VOICE-POLICY
encapsulation ppp
no ip mroute-cache
load-interval 30
no cdp enable
class VoIP_TRAFFIC
set dscp 5
class class-default
set dscp 1
ip route 0.0.0.0 0.0.0.0 Serial0/2/0
Site B
ip cef
description Data T1
encapsulation ppp
no ip mroute-cache
encapsulation ppp
no ip mroute-cache
load-interval 30
no cdp enable
class VoIP_TRAFFIC
set dscp 5
class class-default
set dscp 1
Can you try this config and see if that results in your voice traffic being prioritized ?
GP
I have CEF turned on in both routers. Will there be any voice quality issues if the voice packets go across two different T1's? What are the implications of doing it this way (if any)?
My Qos Config:
class-map match-all voice-signaling
match access-group 103
class-map match-all voice-traffic
match access-group 102
class voice-traffic
priority 500
class voice-signaling
bandwidth 24
access-list 102 permit udp any any range 16384 32767
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
"service-policy output VOICE-POLICY" is applied to both Serial Interfaces
Are their any recommendations for the priority or bandwidth levels under the policy-maps?
VIP Purple
by default, CEF does per-destination load balancing, so you should be ok with your voice traffic.
Actually, the configuration example I have given prioritizes all voice (and voice signalling) traffic. If you want to assign a certain amount of bandwidth for your voice traffic, you would need to know how many conversations you average over the line. Each conversation uses approximately 8kbps. In case of doubt, assign more bandwidth than possibly needed, if the bandwidth is eventually not used by the voice traffic, it will be available to the other traffic anyway...
HTH,
GP
204
