Configuring a Cisco 2921 and two Cisco 3750 switches for a data and voice vlan.
We're trying to install a network with a Cisco 2921 router and two Cisco 3750 switches for use with a data and voice vlan that need access to the internet. The phones are polycom phones which download their firmware/configuration and register through an ftp server out on the internet.  The phones are unable to get out to the internet.  At one point we had issues getting both phones and PC's to grab their IP addresses but we may have cleared that issue.  I'm not sure at this point if the issue is with the router or internet.  Below are sections of the router and switch configs.  For the switch I show the config for the trunk port to the router and two ways I've tried to configure the access ports.
Router1:
ip dhcp excluded-address 10.88.17.1 10.88.17.2
ip dhcp excluded-address 192.168.1.1 192.168.1.19
ip dhcp pool data
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8 8.8.4.4
ip dhcp pool voice
 network 10.88.17.0 255.255.255.0
 default-router 10.88.17.1
 option 42 ip 222.222.222.222
 option 150 ip 222.222.222.222
 option 160 ip 222.222.222.222
 option 66 ascii "ftp://poly:xxx@222.222.222.222"
 dns-server 8.8.8.8 222.222.222.222
ip domain name acmecompany.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
license udi pid CISCO2921/K9 sn FTX12345678
username admin password admin
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/2
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2.10
 description Voice VLAN
 encapsulation dot1Q 10
 ip address 10.88.17.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/2.20
 description Data VLAN
 encapsulation dot1Q 20 native
 ip nat inside
interface Serial0/1/0
 description Primary MPLS T1 Voice Circuit
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 encapsulation frame-relay IETF
interface Serial0/1/0.30 point-to-point
 ip address 233.233.233.234 255.255.255.252
 ip nat outside
 frame-relay interface-dlci 30
interface Serial0/1/0.31 point-to-point
 ip address 10.85.7.2 255.255.255.252
 frame-relay interface-dlci 31
router bgp 65200
 bgp log-neighbor-changes
 network 10.88.17.0 mask 255.255.255.0
 network 192.168.1.0
 redistribute connected
 neighbor 10.85.7.1 remote-as 2222
 neighbor 10.85.7.1 update-source Serial0/1/0.31
 neighbor 10.85.7.1 version 4
 neighbor 10.85.7.1 soft-reconfiguration inbound
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map DIA interface Serial0/1/0.30 overload
ip route 0.0.0.0 0.0.0.0 233.233.233.233
ip sla enable timestamp
logging history size 500
logging trap notifications
logging origin-id hostname
logging host 209.209.209.209
access-list 1 permit 10.88.17.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
route-map DIA permit 10
 match ip address 1
 match interface Serial0/1/0.30
Switch1:
interface GigabitEthernet1/0/15
 switchport access vlan 20
 switchport mode access
 switchport voice vlan 10
 spanning-tree portfast
interface GigabitEthernet1/0/19
 switchport trunk native vlan 20
 switchport trunk allowed vlan 10,20
 switchport mode trunk
 spanning-tree portfast trunk
Trunk port:
interface GigabitEthernet1/0/24
Any ideas of what is wrong?  I have a feeling it could be my serial/frame relay configuration but not sure.  Any kind of advice would be great.  Thanks.
One thing I would look at -
One thing I would look at - you set all options to 222.222.222.222 yet you use primary dns 8.8.8.8. I would think 222.222.222.222 would at least speed up the dns search order.
ip dhcp pool voice
 dns-server 222.222.222.222 8.8.8.8
Good point.  We actually
Good point.  We actually reversed it thinking the google server would help the situation.  I switch it back.
679
