Community Member
Configuring a VWIC2-1MFT-G703 card ...
Hi i have a VWIC2-1MFT-G703 card to configure for the Uk's BT Ip clear service. It will just be used for data. I have followed the steps below, however the command
'voice card' is not recognised by the router - does this mean that I have to upgrade the firmware first to support the feature - the router is a 1841 with IPBASE ? Someone mentioned that I will have to get the IP Voice featureset first.
I am a bit confused why this is need though, since the card is only going to be used for data?
Could an expert confirm that upgrading the featureset is required ?
Kind regards,
Tony.
Router> enable
Enables privileged EXEC mode.
•Enter your password if prompted.
configure terminal
card type {e1 | t1} slot subslot
Step 4
voice-card slot
Example:
Router(config)# voice card 1
Enters voice card interface configuration mode.
•Specify the slot location using a value from 0 to 5.
Community Member
Re: Configuring a VWIC2-1MFT-G703 card ...
could someone please tell me what the minimum feature pack required is to enable the configuration of the card ?
would the Cisco 1841 Advanced Security Feature Pack work ?
Thanks again
Gold
They should work in the base code level in data mode. You don't use the voice command to configure these.
You set the card type and that causes the controllers to appear in the config. You then create the channel group under the controller. This will cause the interface to be created and you configure that like any other serial interface.
Community Member
Thanks! I got it working in the end,
I had to do a show controllers e1 to find the correct slot number, i was putting in 0/0 instead of 0/0/0
Schoolboy error!
1229
