configuring a VWIC2-1MFT-T1/E1 for Data
bberry
All,
This is our first time to configure a VWIC2-1MFT-T1/E1 as we normally use the WIC-1DSU-T1-V2 here in the states but this in Mexico. So far we have used the following to start the configuration but are now stuck. This interface will be used to support a full E1 link back to an MPLS cloud. Some of the details at the moment are simply a guess because we are waiting on the details from the provider. I just want to make sure I have all the pieces in the right place for the complete config. So far I have found very little in the way of a config sample on CCO. All seems to be designed to support voice.
card type e1 0 0
controller E1 0/0/0
framing crc4
linecode ami
clock cource line
channel-group 1 timeslots 1-24 speed 56
This much has given me interface Serial0/0/0:1 which I think is a good sign. Do I now use this to create the point-to-point for the rest of the link details? i.e. IP address, pvc number and other details? It looks like it is following the IMA config I have used in the past. Does anyone know where I can find a sample config or maybe a doc that looks more at a data connection instead of voice?
Thanks in advance
Brent
3 Accepted Solutions
Calin C.
Level 5
Level 5
Hello!
Below you have a sample config that worked when I had to connect to provider MPLS cloud, and then p2p connection. This is frame-relay config, but you can also use ppp. For the framing you have to wait the provider to confirm that it is crc4 or no-crc4. Other details should be provided as well
card type e1 0 0
controller E1 0/0/0
framing CRC4 --> OR NO-CRC4
channel-group 0 timeslots 1-31
description connection_to_MPLS_cloud
* the "channel-group ..." command above will give you interface serial 0/0/0:0
int s0/0/0:0
no ip address
encapsulation frame-relay
no arp frame-relay
int s0/0/0:0.1 point-to-point
ip address x.x.x.x 255.255.255.252
frame-relay interface-dlci xyz
this should give you a p2p connection with provider MPLS cloud. Of course the config above does not apply in all situation. The dlci xyz will have to be communicated by provider...in any case it has to be the same on both ends.
Best would be if you have time to read this for Frame-Relay:
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml
or this for PPP back-to-back:
http://www.cisco.com/warp/public/116/ppp_back.html
The E1 controller is easy to configure after you have the information from provider. The rest is depending on your topology there.
Good luck and let us know if is working or if you need more details.
Cheers,
Calin
Richard Burts
Brent
You will know the real answers when you receive information from the provider. But in making guesses for the configuration parameters I would think that the line code would more likely be hdb3 rather than ami. And I would think that the channel-group timeslots would be 1-31 rather than 1-24. And I would think that the speed was 64 rather than 56.
Yes you are right that what you have configured does give you the serial interface and that is where you will configure the normal interface parameters such as encapsulation, address, pvc, etc.
Rick
Rick
wilson_1234_2
Level 3
Level 3
Brent,
Below is a working config of a remote 1861 router on a Frame-Relay point-to-point to our HQ site.
The HQ side serial interface is 5.1.1.61 255.255.255.252:
card type t1 0 2
controller T1 0/2/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description Link to MPLS
interface Serial0/2/0:0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type cisco
hold-queue 256 in
hold-queue 256 out
interface Serial0/2/0:0.400 point-to-point
description MPLS Circuit
ip address 5.1.1.62 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip flow egress
frame-relay interface-dlci 400 IETF
Calin C.
Level 5
Level 5
Hello!
card type e1 0 0
controller E1 0/0/0
int s0/0/0:0
no ip address
no arp frame-relay
Cheers,
Calin
Richard Burts
Brent
Rick
Rick
wilson_1234_2
Level 3
Level 3
Brent,
card type t1 0 2
controller T1 0/2/0
framing esf
linecode b8zs
no ip address
hold-queue 256 in
hold-queue 256 out
ip flow ingress
ip flow egress
Hey,
Thanks all. These all look like what we have in place. Once we get the details from the provider we will tweek the config and should be good to go.
Brent
