Configuring CBWFQ for VPN tunnel
We'd like cofigure QoS traffic between the router 1800 and ASA 5540 firewall. Is it possible to implement? Does ASA support QoS? If both ends are routers, it sounds it work? but never did between router and ASA.Please advice
Bronze
Re: Configuring CBWFQ for VPN tunnel
Follow the URL for the configuration for the CBWFQ with IPsec VPN Using GRE Tunnel which will help you :
http://www.cisco.com/en/US/products/ps6635/products_white_paper09186a0080189048.shtml
the follwoing link will give you the exact answer to you case
which is QOS between firewall and router through VPN
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008080dfa7.shtml
good luck
please, Rate if helpful
159
