Configuring channelized E1 G.703 Head office and branch routers
We have bank with a Head office router 2811 and third party routers at the 8 branch offices. The branch office are to be connected to the head office router. At the head office
The ISP connection is channelised E1 G.703 2mbps link at head office . The branch offices have either 64kpbs or 256kbps connections.
I am using HWIC 1ce1t1-pri card on the cisco router. The ISP has provided the time slots
The branch office connections are V.35 from the ISP.
here is the configuration  of head office cisco router.
controller E1 0/1/0
framing NO-CRC4
clock source internal
channel-group 1 timeslots 1-4
channel-group 2 timeslots 5-8
channel-group 3 timeslots 9-12
channel-group 4 timeslots 13
channel-group 5 timeslots 14
channel-group 6 timeslots 15
channel-group 7 timeslots 16
channel-group 8 timeslots 17
interface Serial0/1/0:1
description a
ip address 192.168.99.2 255.255.255.252
encapsulation ppp
interface Serial0/1/0:2
description b
ip address 192.168.99.10 255.255.255.252
encapsulation ppp
interface Serial0/1/0:3
description  c
ip address 192.168.99.22 255.255.255.252
encapsulation ppp
interface Serial0/1/0:4
description d
ip address 192.168.99.6 255.255.255.252
encapsulation ppp
interface Serial0/1/0:5
description e
ip address 192.168.99.14 255.255.255.252
encapsulation ppp
interface Serial0/1/0:6
description f
ip address 192.168.99.18 255.255.255.252
interface Serial0/1/0:7
description g
ip address 192.168.99.26 255.255.255.252
encapsulation ppp
interface Serial0/1/0:8
description Ponda branch
ip address 192.168.99.30 255.255.255.252
encapsulation ppp
The E1 controller show status at up with no errors when "show controller e1 0/1/0 " is done
but the   all Serial 0/1/0:x interfaces show  "interface up line protocol down"
Here is the branch office router configuration
interface serial x/x
Ip address 192.168.99.x  255.255.255.252
encapsulation ppp
bandwith  64kps or 256kbps
Again at the branch offices i get
serial inteface is up , line protocol is down.
Am l missing something here. please help urgently.
I am also attaching the screen shot of  head office router  for " show controller e1 0/1/0 " and show "serial interface "
i dont have screenshot  of any branch office router
please help.
Re: Configuring channelized E1 G.703 Head office and branch rout
Just a correction.  the framing is crc4 .
The ISP  branch modem  support framed timeslots.
Hall of Fame Super Silver
Hello Favol,
check with service provider again the timeslots assignment and if you need to do something similar on branch offices
no frames are received on each serial interface as you can see "Last input" line shows 19 minutes ago in show interface output.
As a result of not receiving L2 keepalives (in your case they should be PPP) the state of each serial interface is up/down
This would happen also if mismatching encapsulations were used at the two ends but the fact that no packets are received leads to a possible mismatch on mapping of E1 timeslots or a missing configuration on their TDM equipment they need to convert in N timeslots each branch circuit and then to map the N timeslots in the correct position on the E1 towards central site.
SP has to perform switching of timeslots in the correct positions in order to achieve connectivity
Hope to help
Giuseppe
Thanks Giuseppe
I will be going to the ISP exchange with the head offfice router and the branch office router both are cisco 2811.
becoz even i feel its a issue with thier end.
I managed to get the setup working. It was an ISP issue. Just want to let people who will configure channelized e1 with timeslots for first time, the
above configuration is correct. you need to only confirm 2 things from ISP. first is the framing i.e  no-crc4 or crc4 , second is the time slot for each branch.
The time slot has to be given by the ISP.
Line code and path code violations mostly is to do with ISP line as i found out.
Thanks guy for your inputs
1260
