08-17-2008 03:14 AM - edited 03-03-2019 11:10 PM
I am trying to configure DHCP and NAT at home on my Cisco 870. Here are the steps I used to create my DHCP:
Router(config)# interface ethernet0/0
Router(config-if)#ip address 172.168.1.1 255.255.255.224
Router(config)# ip dhcp exclude-address 172.168.1.1 172.168.1.4
Router(config)# ip dhcp pool Home
Router(dhcp-config)# network 172.168.1.0 255.255.255.224
Router(dhcp-config)#default-router 172.168.1.1
Router(dhcp-config)exit
But I cant get NAT configured on my 871. Can someone give me a step by step instruction on how this is done. Thanks in advance.
08-22-2008 01:05 AM
So to configure my router for DHCP and NAT is this correct?
Router(config-if)#ip address 172.16.1.1 255.255.255.224
Router(config)# ip dhcp exclude-address 172.16.1.1 172.16.1.4
Router(dhcp-config)# network 172.16.1.0 255.255.255.224
Router(dhcp-config)#default-router 172.16.1.1
and then NAT:
router(config)# access-list 1 permit 172.16.0.0 0.0.255.255 (or should I use 0.0.0.0)
router(config)#ip nat inside source list 1 int f0/4 overload
router(config)#int f0/0
router(config-if)#ip nat inside
router(config-if)#int f0/4
router(config-if)#ip nat outside
08-22-2008 04:42 AM
I assume the ethernet0/0 and the fa 0/0 is a typo? This should work fine.
You access list 1 does not really matter a lot since you have no other possible addresses you are trying to exclude. You could just use a PERMIT ANY. If you wanted to be exacting you should use PERMIT 172.16.1.0 0.0.0.31
08-23-2008 02:25 AM
when I tried to configure DHCP on one of the interfaces (F0-3), I got the error "% IP addresses may not be configured on L2 links". Can someone explain what that means?
08-26-2008 12:50 AM
After googling that error, I find out that the 871 (along with other 8 series) has an intergrated switch built into it. Some of the people suggest creating Vlans and assigning IP addresses to the Vlan, will this work? Also how would this work with NAT. Im confused :(
08-26-2008 01:06 AM
Hello Chris,
Yes you have to create vlan interface and assign IP to make DHCP work in this case. It is not that confusing, here is an example
no ip address 172.16.1.1 255.255.255.224
interface Vlan 10
ip nat inside
interface Fa 0
switchport mode access
switchport access vlan 10
interface Fa 1
interface Fa 2
interface Fa 3
Please do not forget to rate the posts with 4 or above grades if resolved your issue.
08-26-2008 06:09 AM
with your example I am using Vlan10 to direct all traffic out of F0/0 correct? Well the other ports still work if I connect something to it?
How will this effect my DHCP?
