configuring eigrp over radio links
tomocisco
my company is using radio links to link up our recently opened branches to the head office. i am among the team of network engineers. we are deploying all cisco routers and switches, specifically we are using 2800series router and 2950 switches. we decided todeploy eigrp as our routing protocol. after configuring eigrp, we could not link up until we decided to use static routing, the problem is that as we expand, static routing may no longer be feasible. please can somebody help me with the right configuration for eigrp over radio link, the bandwidth of the link is 9Mbps. thanks
andrew.prince
Level 10
Level 10
Not entirely sure if you can multicast over radio! Perhaps another netpro has done this.
However I would create GRE tunnels over the radio to the remote sites and encapsulate EIGRP into GRE - works a treat.
HTH>
Defo check is the Link supports multicast!
As andrew said use GRE tunnels or configure neighbour statements.
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a008012dac4.shtml#ten
HTH - Pls rate if it does!
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
