Community Member
Configuring Gigabit Ethernet ports in a OSM-4OC3-POS-SI+ module
I'm trying to configure one of the GE port of a OSM-4OC3-POS-SI+ module as a TRUNK port, and another one as ACCESS port in a Cat6503 but when I try to configure:
R-MAN-A(config-if)#switchport mode access
Command rejected: Gi2/2 not a switching port.
Do you know if these ports only can work as ROUTED ports? or maybe is it possible to configure them as TRUNK or ACCESS ports ?
Thanks a lot in advance
1 REPLY
Community Member
Re: Configuring Gigabit Ethernet ports in a OSM-4OC3-POS-SI+ mod
Try configuring it as a switchport first:
switch#sh run int g1/1
Building configuration...
Current configuration : 61 bytes
interface GigabitEthernet1/1
no ip address
shutdown
end
switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)#int g1/1
switch(config-if)#switchport mode acc
Command rejected: Gi1/1 not a switching port.
switch(config-if)#
switch#
158
