Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
configuring Port-Channel on Cisco 3825
Hi everybody,
does NM-2FE2W_V2 on Cisco 3825 support Etherchannel or 802.3ad?
Best regards
Stefano
Re: configuring Port-Channel on Cisco 3825
Hi ,
12.4 IOS starting from IP BASE feature set does support Etherchannel - Flexible PAgP
Provides enhancements and new functionality to existing EtherChannel port bundling features, including non-contiguous port bundles, port bundles of up to eight ports, and port bundles across multiple modules
HTH..rate if helpful..
Thank you!
If I use on board GigabitEthernet interfaces it works.
If I use FastEthernet interfaces on NM-2FE2W_V2 it doesn't work.
Why?
One additional information:
on the other side of the Etherchannel I have a Cat 3750G-24TS. Is it possible to have the Etherchannel working with FastEthernet on router side and GigabitEthernet on switch side?
Many thanks
Stefano
705
