Configuring Redundancy on 3 LINKS
okoroji80
What i want to achieve:
1. User 1,2,and 3 will be accessing the server resource from different locations
2.  User 1, will use link A as its Primary link, B as secondary, C as  tertiary such that in the event of A failing it will automatically  switch over to B. IF B fails it will use link C.
3. The scenario 2 above is applicable to user 2 and 3
24 Replies 24
John Blakley
It would help if you could tell us what the links are. What type of connection are they? Are they same or different ISPs? What routing protocol?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks Mr. John,
the three links are all different links (ISP)
No routing protocol ,only static routes
the issue is on how to setup the 3 or more users to failover the 3 linsk automatically
eg:
ip route 1.1.1.2 255.0.0.0 4.4.4.3 track 15
ip route 1.1.1.2 255.0.0.0 3.3.3.2 5
ip route 1.1.1.2.255.0.0.0 2.2.2.1 10
User1 Ip:1.1.1.2 Gw 1.1.1.1
user2 ip:1.1.1.3 Gw 1.1.1.1
User3 ip:1.1.1.4 Gw 1.1.1.1
Hi Jude,
It looks like all three users are from same subnet. I think that PBR should do the job.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hello
First of all this is a duplicate posting but its just been renamed so can you please close one of them
https://supportforums.cisco.com/thread/2263023
Regarding you query:
Try using ip sla to track your router interfaces
From R2 perspective (if i have the ip addressing corect) -  Also this will then need to be duplcated on R1 but obvisouly the addressing needs to be change to accomodate.
Ip sla 1
Icmp-echo 2.2.2.1 source-ip 2.2.2.2
Freq 5
Timeout 2000
Ip sla scheduled 1 start now lifetime forever
Ip sla 2
Icmp-echo 3.3.3.2 source-ip 3.3.3.3
Freq 5
Timeout 2000
Ip sla scheduled 2 start now lifetime forever
Track 1 rtr 1
Track 2 rtr 2
ip route 10.1.1.2.255.0.0.0 2.2.2.1 250 track 1
ip route 10.1.1.2 255.0.0.0 3.3.3.2 251 track 2
Ip route 10.1.1.2 255.0.0.0 4.4.4.3 252
Res
Paul
Kind Regards
Paul
okoroji80
thanks.
that means i should have three (3) sets of IP SLAs for the three  (3) Users ?
sorry, i did not get the comment you made above '' it should be duplicated on R1''
or could you please  highlight more on the comment above "
From R2 perspective (if i have the ip addressing corect) -  Also this  will then need to be duplcated on R1 but obvisouly the addressing needs  to be change to accomodate. ""
thanks
blau grana
Level 7
Level 7
Hi Jude,
I dont think Paul's solution is correct. Yes, it offers redundancy but host A, B and C will always use same link. If all links are working all hosts will use link A, if A fails they will use link B and link C will be last option.
As I understand your request, you want each host use different link if all links are working and each link will be backup for other links from user's point of view.
I think this can be done only with Policy Based Routing.
Best Regards
Hi Blau,
you got the point quite correct.
could you please help with the config to achieve this .
Hi Jude,
this should do the trick, I didnt see IP plan in your diagram so I just made up my own. This PBR configuration should work regardles of your routing configuration.
10.0.0.0/24 - subnet where three hosts reside
10.255.255.10/24 - ip address of server
       .1   10.10.10.0/24   .2 -
R1 - .1   10.20.20.0/24   .2 - R2
       .1   10.30.30.0/24   .2 -
R1 configuration
interface XYZ
description link to server
ip address 10.255.255.1 255.255.255.0
ip policy route-map RM_PBR
ip access-list extended HOST_A
permit ip host 10.255.255.10 host 10.0.0.1
ip access-list extended HOST_B
permit ip host 10.255.255.10 host 10.0.0.2
ip access-list extended HOST_C
permit ip host 10.255.255.10 host 10.0.0.3
route-map RM_PBR permit 10
match ip address HOST_A
set ip next-hop 10.10.10.2 10.20.20.2 10.30.30.2
route-map RM_PBR permit 20
match ip address HOST_B
set ip next-hop 10.20.20.2 10.30.30.2 10.10.10.2
route-map RM_PBR permit 30
match ip address HOST_C
set ip next-hop 10.30.30.2 10.10.10.2 10.20.20.2
R2 configuration
interface XYZ
ip address 10.0.0.254 255.255.255.0
permit ip host 10.0.0.1 host 10.255.255.10
permit ip host 10.0.0.2 host 10.255.255.10
permit ip host 10.0.0.3 host 10.255.255.10
set ip next-hop 10.10.10.1 10.20.20.1 10.30.30.1
set ip next-hop 10.20.20.1 10.30.30.1 10.10.10.1
set ip next-hop 10.30.30.1 10.10.10.1 10.20.20.1
Best Regards
....But do i still need the ' ip route with tracking on the router , or the PBR above is all that is needed ?
of course you still need to configure ip routing (static routes with tracking or IGP, lets say OSPF with different cost for each link). PBR will only take of specific traffic matched by ACLs referenced in route map.
Best Regards
Ok.
Basically i have this also configured in addition to the IP SLA
USER1
USER 2
ip route 1.1.1.3 255.0.0.0 3.3.3.2 track 20
ip route 1.1.1.3 255.0.0.0 2.2.2.1 15
ip route 1.1.1.3 255.0.0.0 4.4.4.4 10
USER3
ip route 1.1.1.4 255.0.0.0 2.2.2.1 track 30
ip route 1.1.1.4 255.0.0.0 4.4.4.3 25
ip route 1.1.1.4 255.0.0.0 3.3.3.2 15
  IP SLA
User1 IP SLA
ip sla 15
icmp-echo 4.4.4.3 source-ip 4.4.4.4
timeout 120
threshold 100
ip sla shedule 15 life forever start-time now
track 15 rtr 15
track 15 ip sla reachability
User2  IP SLA
Let me know if the IP SLA is not needed ?
thanks.
The answer is, it depends. What type of links do you have between R1 and R2? Lets say if link A fail, will line protocol on matching interfaces go down? If not corrupted next-hops will stay in routing table so PBR will still use them and traffic will be blackholed.
IP SLA is good solution to track reachability of next hops if or you can some other workaround.
Do you use these links only for traffic between server and specific hosts or it will also be use to transport some other traffic, what routing protocol do you use in your domain?
Best Regards
.... Yes for Server and specific hosts
----- No routing protocol in use for now. just the static routes.
thanks
ok, if these three links are dedicated only to traffic between server and three hosts, PBR should do the trick. In other thread you mentioned that cat6 cable connect R1 and R2 routers IP SLA should be used to verify next hops reachability.
Best Regards
