Configuring VWIC2-2MFT1-T1/E1 in 2821
I have a 2821 with a VWIC2-2MFT1-T1/E1 module installed in HWIC slot1, a WIC 1DSUT1 in HWIC slots 0 and 2. I am trying to configure the VWIC2-2MFT1-T1/E1 module for MLPPP connection. The command "card type t1 0" was issued and accepted by the router but I don't see the VWIC2 when I do a ?sh ip int br.? Therefore, I am having a hard time configuring the two interfaces on the VWIC. Any suggestions as to what I should do to resolve the issue?
Please see the screen capture from "sh diag" in the attachment.
2 ACCEPTED SOLUTIONS
Re: Configuring VWIC2-2MFT1-T1/E1 in 2821
The 'card type' command would make the router aware of the card in the slot. This can be verified by doing a 'show diag' from the privilege exec mode. To configure the serial interface you would need to configure the controller first.
Have a look at this link for configuring the controller;
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_configuration_example09186a008052c920.shtml#Configurations
Sundar
define controllers too... use this command or something similar, then you will see the serial interfaces in sh ip int bri command output.
controller T1 0/0
framing sf
linecode b8zs
channel-group 0 timeslots 1-24
Silver
Can you give me IOS name.
Dharmesh Purohit
Sundar
The IOS version that is on the router is C2800NM-SPsSERVICESK9-M, Version 12.4(3a)
controller T1 0/0
framing sf
linecode b8zs
Removed
450
