08-03-2010 09:08 AM - edited 03-04-2019 09:17 AM
Imagine service provider tells me that I have to use G.703 (no support for V.35) interface type in order to get my site up and running.
Question 1:
From reading the document below (Table 2), my understanding is that
my existing E1/T1 cards like VWIC2-1MFT-T1/E1 will not support G.703, correct?
From reading this document below, it seems I would need to buy new WIC's
model VWIC2-1MFT-G703 for example, right.
Question 2:
Is the physical interface for the G.703 and respective WIC interface a RJ-48?
Just want to confirm it is not RJ45C or BNC.
• Data-As a WIC for T1/fractional T1, and E1/fractional E1 applications. The 1- and 2- port E1 versions include models that support unframed G.703. To simplify remote management issues the T1 version integrates a fully managed data service unit/channel service unit (DSU/CSU) and the E1 version includes a fully managed DSU...."
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
Solved! Go to Solution.
08-03-2010 01:01 PM
Hi there,
You are right, regarding question 1.
These types of circuits require these G703 VWIC cards.
Only the following cards support them for the lower end platforms (28xx, 37xx, 38xx, etc):
VWIC2-1MFT-G703=
VWIC2-2MFT-G703=
Regarding question 2, yes, these VWIC cards do support RJ-48 pinout connectors.
Arun
08-03-2010 01:01 PM
Hi there,
VWIC2-1MFT-G703=
VWIC2-2MFT-G703=
Arun
