You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Congestion Management
I am hoping to get some advice as to what method of congestion management I should use.
We are a heavy Terminal Server environment. We have 14 or so remote sites connected via 256K frame relay circuits to our host which is a full T1.
We want to give terminal server connections total priority and have everything else take the back seat in terms of bandwidth utilization.
I thought Frame Relay IP RTP Priority would work, but it appears to only apply to UDP traffic.
Priority queueing is looking like the next best option.
Dang, so many options to achive the same thing is making it hard to pick one.
Any thoughts?
Thank you,
Denny
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Purple
Re: Congestion Management
Hi Denny,
You can do this in that case:
int serial1/0.16
ip address....
frame-relay traffic-shaping
frame-relay interface-dlci 16
class Shaper1
frame-relay interface-dlci 17
class Shaper2
map-class frame-relay Shaper1
frame-relay cir xx
frame-relay mincir xx
service-policy output LLQPolicy1
map-class frame-relay Shaper2
frame-relay cir xx
service-policy output LLQPolicy2
As you can see, you can apply a different map-class to each PVC, which will determine the service that particular PVC gets. So you can configure different shaping rates per PVC.
Hope that helps - pls rate the post if it does.
Paresh
Purple
Hi Danny,
Use low latency queueing (LLQ):
class-map TermServerTraffic
match access-group 101
policy-map LLQPolicy
class TermServerTraffic
priority 128
class class-default
fair-queue
int serial1/0.16
ip address....
frame-relay class Shaper1
frame-relay cir xx
access-list 101 permit tcp/udp .....
Apply such a policy at both ends. This policy will give priority to term server traffic up to 128k (you can of course change this figure to suit you)...
Hope that helps - pls rate posts that help.
Paresh
Thank you for responding. In your example it appears you apply the map-class to a Sub-Interface. In our case, all of our DLCI's are defined under the Serial0/0 interface.
Would this example force all remotes to share 128K or would each PVC get 128K?
Thank you,
Denny
Purple
Hi Denny,
int serial1/0.16
ip address....
class Shaper1
class Shaper2
frame-relay cir xx
frame-relay cir xx
Paresh
That is perfect.
Thank you,
Denny
105
