Community Member
Connecting 2 switches at L2 (virtual ethernet cable) over VPN. Is it possible ?
Consider the following setup.
Lab A with Switch SW1
Lab B with Switch SW2
     Lab A and Lab B have an IPSec VPN tunnel over the internet (no mpls).
     They have 2 cisco 2811's between which the ipsec tunnet is established.
Is it possible using some technology (Ethernet over IP ?) to have a "virtual cable" to connect
                     SW1 <-------   virtual ethernet ---------> SW2,
so that they can exchange BPDU's and participate in STP, and form 802.1q trunks etc ??
The idea is to build a switching lab, to learn switching by sharing equipment.
      Its NOT to pass data for production.
The only other alternative is to simply borrow SW2 from Lab2, and physically connect it to SW1.
            But thats no fun !
I dont know too much about VPN's etc, but
Can this be achieved using a GRE tunnel over IpSec, and then bridging the gre / tunnel interface with a spare ethernet interface
on the routers ?
Any ideas if this is possible ?
Community Member
Re: Connecting 2 switches at L2 (virtual ethernet cable) over VP
I guess this may be possible using UTI / L2TPv3 on higher end cisco routers (7200 etc).
  Can anyone confirm ?
Another link I found, seems to suggest that this CAN be done over GRE.
               http://www.mikrotik.com/documentation/manual_2.7/Interface/EoIP.html
   But what I have read so far on Cisco, seems to suggest that GRE can only tunnel IP or PPP frames.
Any input would be appreciated.
Community Member
Apparently, this can also be achieved using DLSw+ or bridging over GRE tunnels (unsupported feature)
http://www.net-gyver.com/?p=1000
http://www.net-gyver.com/?p=952
406
